Can I upgrade a C1861-SRST-F/K9
giovambattista
Can I add a AIM-CUE to a C1861-SRST-F/K9 bundle ... I purchase the wrong bundle and I need VM ... Configurator doesn't allow the upgrade the router and I don't see a licence ... I wanted to know if Cisco supports this upgrade ?
paolo bevilacqua
I think that nothing prevents a regular AIM-CUE to be fit in the router and work with the appropriate SW image.
crbates
Level 5
Level 5
If you look here: http://www.cisco.com/en/US/prod/collateral/routers/ps5853/ps8321/product_data_sheet0900aecd806c4dce.html
Table 2 lists it as an option, but I don't see a part number.
You are right, but knowing cisco, I think the AIM-CUE that sells as spare, is the very same that goes as optional with the 1861.
peraocompany
No, 1861 have not any AIM slots inside. CUE processor and DRAM/FLASH slots are included in SRST-F bundel on main PCB. How upgrade it I dont know.
