Can incomming blocked numbers be found?
Chris Alvarado
I work for a state and local municpality and every so often we get a pissed off local that threatens employees. The calling party blocks there number from being viewed so we can not find out who it is. I have run a call detailed record but the calling party field is blank. Is there anyway I can find these actual numbers or is that just not possible? Or can I stop blocked numbers from being allowed in our phone system? Thanks...
Jaime Valencia
If you do not get the calling number in the setup messages, there's no way for you to find that out. You would need to involve telco.
If you're using H323 you can block calls without ANI, just search CSC and you'll find plenty of posts with the info if you're interested.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Ayodeji Okanlawon
If you have h323 gateway you can do this.. Configure translation rules as shown below:
voice translation-rule 11000
  rule 1 reject /[^0-9]$/
voice translation-profile CALL_BLOCK
  translate calling 11000
dial-peer voice (incoming dial-peer(s) tag(s)) [pots | voip]
   call-block translation-profile incoming CALL_BLOCK
   call-block disconnect-cause incoming invalid-number
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
