05-02-2013 06:36 PM - edited 03-16-2019 05:07 PM
interface Integrated-Service-Engine0/0
ip unnumbered Loopback0
ip virtual-reassembly in
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
and
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
already checked the flash everything is there, have ip http server and secure-server with authentication local
I can ping the service module but when i put the ip address in the browser the webpage does not open
anyone else has this problem?
I have troubleshooted by factory restore default and reloaded the voice module
05-02-2013 08:17 PM
Can you access the CME GUI?
By any chance, are you using Inspection on the UC540? If so, you may add HTTP and HTTPS.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
05-03-2013 05:28 AM
Open terminal to CUE and verify what is going on from that side.
05-03-2013 06:15 AM
Hey guys
Yes I can open the CME GUI and I am using inspection it has "ip inspect name SDM_LOW https" but not http can that be a issue ? I have also check the status of the service engine and it is ready state. the service-engine session also opens
05-03-2013 08:59 AM
Yes, it is a possibility, please try adding HTTP to the Inspection and let us know!
Jorge Armijo
05-03-2013 01:36 PM
hi
It looks like it is a routing issue! The router in question is located a remote site and I am using teamviewer to access a machine that is connected to that router. The wifi is on to allow me teamviewer access but when wifi is on i get the error i asked the customer to turn of the wifi and login and let me know what happens and it works. However I need the wifi enabled to do my job. The wifi routers to another router with a subnet interface is the gateway used by the data vlan.
