can not connect to ISM
ashleyisa
I am starting to configure a 2921 with an ISM for voicemail.
I've configured as follows, but telnet and ssh advises that the connection is refused:
RTR#ssh 192.168.4.5
% Connection refused by remote host
configuration that i have added:
interface ISM0/0
ip unnumbered GigabitEthernet0/1.4
service-module ip address 192.168.4.5 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 192.168.4.3
interface GigabitEthernet0/1.4
encapsulation dot1Q 4
ip address 192.168.4.3 255.255.255.0
ip route 192.168.4.5 255.255.255.255 ISM0/0
I can ping it but it wont let me in????
Do they get sent with some sort of default config which is stopping me accessing the device?
THis is how you access the ISM :
Router# service-module service-engine slot/port session
Trying 10.10.10.1, 2129 ... Open
SE-netmodule> enable
Password:
SE-netmodule#
SE-netmodule con now available
Amer
Password:
SE-netmodule#
Amer
Must be having a brain freeze lol
I used to use these regularly, but have'nt touched one in a couple of years
Thanks for the speedy reply Amer
