IP Telephony and Phones
Labels
Resolved! IDLE URL
Hi,If i configure IDLE URL in enterprise parameters of CUCM 7.x, and when later when user login into a phone using Extension mobility, will these IDLE URL will still be working or it will be over written. Device profile does not have IDLE URL paramet...
Hi,I have configured a SIP trunk in CCM. There are no problems with incoming calls but  I need to change SIP headers for outgoing calls. I need to send host name instead of IP address and I need to add "user=phone" in the header. ieINVITE sip:6303333...
Hello,I have a problem with the UCCX which displays error on the Backup page as per the attached:•    UCCX System version: 8.0.2.11003-10•    Installed on  Linux                     admin: show version active Active Master Version: 8.5.1.10000-26Acti...
I am starting to configure a 2921 with an ISM for voicemail.I've configured as follows, but telnet and ssh advises that the connection is refused:RTR#ssh 192.168.4.5% Connection refused by remote hostconfiguration that i have added:interface ISM0/0 i...
ashleyisa by Level 1
  • 1655 Views
  • 2 replies
After a power failure at a site the cisco phones is giving the following message" Link down limited functionality"I have checked the config and also checked that the WAN links were up. Restarted the Gateway and the phones and still getting the same m...
