Configuring Catalyst 3560 for 1 voice VLAN and multiple data VLANs
s.dovinte
Hi all,
We currently have our IP Phones connected to the switches (4 catalyst 3560). The Callmanager assigns the phone's ip by DHCP.
Our data and voice LANs are completly separated, logically and physically.
We want to use the IP phone's switch to connect our PC's to the phones and these to the Catalyst Switches.
Our goal is to deploy one VLAN for voice, and at least 5 VLans for data (we want to spearte the data of the different departments). As I said the phones are configured to obtain an ip of the CallManager's DHCP Server, our office has an internal DHCP server and we have a central router to make the routing with the vlans...
Anyone has a similar scenario? We need help to configure the switches properly.
6 Replies 6
From where i can see , you have no problem with your scenario , where exactly is your problem , is it configuration or desiging .
If it is configuration , the configuration will depends on your netwrok setup.
Let's start with a couple of questions so i can give you the complete scenario:
1- do you have a core switch or the routing is terminated on the sub interface on a router ?
2- what exactly is the setup now.
3- do you have a managment VLAN for the switches.
4- is the call manager is on smae vlan or on the data vlan ?
Amer
Hi Amer,
Configuration or desiging, I guess both... we are a little bit lost
I'm goingo to try to answer your questions:
1 - we don't have a core switch for voice, the voice routing is terminated on the voice routers.
2 - Now we have voice lan and our data lan. The voice lan has four dedicated switches and two dedicated voice routers, the CallManager and IPCC clusters are also connected on this voice lan. I paste a switch conf:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname BBBB
enable secret 5
username admin privilege 15 secret 5
aaa new-model
aaa authentication login default local
aaa session-id common
ip subnet-zero
ip dhcp snooping vlan 20
ip dhcp snooping
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 20
switchport mode access
interface FastEthernet0/2
switchport voice vlan 20
spanning-tree portfast
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
ip dhcp snooping trust
interface FastEthernet0/6
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
description Off temporaly
shutdown
interface Vlan1
ip address 192.168.7.7 255.255.255.0
interface Vlan20
ip address 192.168.70.7 255.255.255.0
ip classless
ip http server
logging 192.168.0.107
radius-server source-ports 1645-1646
control-plane
3 - No we don't have a management Vlan for switches. I see we have defined and Vlan1 but it's no applied to any port. All ports are on Vlan20. As I said this switches are only for IP phones right now.
4 - The CM is connected to this switches but we do the routing with the voice routers so the CM can reach our data LAN. I mean, we have not any VLAN defined for data, there are two physical separated LANs -Voice and Data-
I'm going to try to do a scheme:
you should first create seperate voice vlan (in your configuration, voice and data vlans are same)
and then put your callmanger servers in voice vlan , then just on all switch ports add this configuration
{ switchport mode access
switchport access vlan [your departments vlan number]
switchport voice  vlan [voice vlan number]
spanning-tree port-fast }
you should consider this: if you don't have vtp server, you must create voice vlan on all of your switches.
ip phones can obtain vlans information by cdp from switches and automatically send dhcp request at voice vlan to callmanager(dhcp server)
computers cant obtain ip address from dhcp server in data vlan
From what i see , the design looks like cascading .
The cisco voice gateway is connected via one interface to a cisco switch then the cisco switch is connected to the other switches...
What you need to know is :
1- create a sub interface on the voice gateway interface for every vlan you want to configure (5 vlans (data and voice))
2- the port which is connected between the voice gateway and the switch should be trunk.
3- i suggest to use this switch as a server VTP , and the other are clients , in this case , when you create the vlans , they are all going to pop-up on all the switches , all what you have to do is to create a int vlan for management on the switch.
4- the default gateway is going to be the voice gateway interface (for routing).
for the ports that the ip phones should be connected to , do the following :
switch mode access
switch port access vlan (data vlan)
switch port voice vlan (voice vlan)
for the ports that are going to be connected to the CUCM :
only do
switch port mode access
switchport access vlan (voice vlan)
Amer
Thank you both, Amer and Ali.
I'm going to start the deployment of this scenario next week and i'll try to keep you posted.
Thanks again!
Sorry for the delay. i'm still on the early stages of this deployment but it all seems to be on the right way.
First we deployed a scenario like this for testing:
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00800ffdcc.shtml
Everything went ok and the LAN/Voice behaviour was pretty good.
Now we are testing a few computers on the production enviroment with the scenario described above on my second post. Next Monday i'm going to start the migration and let you know. I have to test the network connectivity, the voice quality, etc.
We also have to test the listening and recording function of the Cisco Supervisor, don't know if I need anything else to make that function work.
Anyway, i'll keep you posted.
