Can not login to Publisher in GUI or CLI mode
Can any one help me to sort out this problem, I can not login to my Publisher either in GUI mode or CLI mode,If i try to open in GUI mode, it is not responding at all.In CLI mode, after entering the user name, Password prompt is not showing at all.
But I can able to login all my Subscribers in GUI or CLI mode.
Can any one help to clear this issue.Can i restart my Publisher physically...?
AZ.
Robert Thomas
Level 7
Level 7
Seems like your server could be in readonly mode.
Can you try to reboot the server and then run recovery disk to check for filesystem consistency?
Hi AZ,
You can try connecting Monitor to Publsiher and find out the cause behind that.
After that , u can act as suggested by Mr. Robert.
regds,
aman
