Can not send fax...showing Scheduled to be Sent
KpaH4iTooo
I am using RightFax 9.4 (Business Edition). The topology of the solution is PSTN/FAX-->VG-->CUCM via H.323-->RightFax
From the Fax server I am unable to send any fax. Using Fax uitity while sending fax it shows Scheduled to be Sent.
I am using SR140. In the Brooktrout I configured the CUCM as default  h.323 gateway. also in CUCM configured fax server as h.323 gatway. I am  suspecting that my VG configuration may have some problem.
I start wireshark on fax server and that is no activeties after Sent fax from FaxUtil.
17 Replies 17
That is all OK now, the faxes are send OK. The connection scheme - GW-sip-Rightfax server. Transmission error status says that may be fax rate is very fast.
Hi Alexander,
Are you meaning that outgoing faxes are working in the following scenario ?
"PSTN --GW-sip-Rightfax server."
If you are facing issues with fax speed, did you try setting the speed to a lower value using the fax rate command? (you can use this under voice service voip or individual dial-peer)
Bala.
PS: Please rate useful posts. Please mark the thread as answered if the issue is resolved.
Yes, outgoing faxes are working in the following scenario.
Now is all OK
