Can't configure vic2-2fxo on 2811
WillemBont_2
I am trying to configure my 2 fxo ports on my 2811 router.
The problem is that I can't acces the voice ports.
The voice card is recognized by the system:
2811CME#sh inv
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V05 , SN: FHK1223F0BV
NAME: "2nd generation two port FXO voice interface daughtercard", DESCR: "2nd generation two port FXO voice interface da
ughtercard"
PID: VIC2-2FXO=        , VID: V  , SN: FOC09111DV8
But when I enter this command:
sh voice port sum
        IN       OUT
PORT           CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
50/0/1         1      efxs     up    up   on-hook  idle     y
50/0/2         1      efxs     up    up   on-hook  idle     y
50/0/3         1      efxs     up    up   on-hook  idle     y
50/0/4         1      efxs     up    up   on-hook  idle     y
it only shows fxs ports (which are not in the 2811), and this happens trying to acces the fxo ports:
2811CME(config)#voice-port ?
  <50-50>  Voice interface slot #
2811CME(config)#voice-port 50/?
  <0-0>  Voice interface SubUnit #
2811CME(config)#voice-port 50/0/?
  <1-4>  Voice interface port # within vic
2811CME(config)#voice-port 50/0/1
% Invalid input detected at '^' marker.
The image I use is C2800NM-ADVIPSERVICESK9-M, Version 12.4(8)
I have also tried to change slots and even insert the fxo card in a NM-HDV module: it makes no difference.
Any suggestions?
Thanks in advance.
Willem
paolo bevilacqua
You don't have the necessary PVDM2-xx module needed to enable voice-ports.
If you have searched about this common occurance, you would have saved time in getting the answer.
Hi Paolo,
Thanks for your super-fast answer.
I guess I need more hardware.
Best.
Willem
