Can't install 7965 phones
mcdonovan
I am trying to install 7965 phones on CM version 4.1(3)sr5b. I added the firmware to the TFTP directory but I don't see an option under Device Defaults to for a Cisco 7965 or 7945 phone. Also, when adding a phone I don't see Phone type* 7965 or 7945 in the drop down choices. Any assistance appriciated.
Although you have the correct call manager version to support the phone as per the compatibility matrix, and you have the firmware...you need to download the latest device pack in order to be able to have the options to add the phone to the system. The device pack download can be found at the following link:
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=4.1%2878%29&mdfid=278853938&sftType=Unified+Communications+Manager%2FCallManager+Device+Packages&optPlat=&nodecount=2&edesignator=null&modelName=Cisco+Unified+CallManager+Version+4.1&tree...
Hope that helped. If so, please rate.
Thanks Kenneth! I'll upgrade the device pack. Appreciate the link too!
