IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5641 Views
  • 14 replies
Does auto qos automatically enabled the priority out command when enabling it on a switchport. See config below - priority-queue out is missing. Does it need to be added with auto qos?interface GigabitEthernet1/0/1 switchport access vlan xxx switchpo...
mlouis by Level 1
  • 412 Views
  • 2 replies
Can you have a SRST deployment along the lines of the following:Central site A with a link to Site B which in turn is linked to Site C and Site D- Site B is acting as a Hub for Siet C& D with each site B,C&D having a SRST router another option we ha...
iptuser55 by Level 6
  • 404 Views
  • 3 replies
i HAVE A CALLMANAGER 5.1 the latest code and the active partition is running at 97% so RTMT is cutting a low disk space warning. Has anyone seen this or know of a fix. I haveused the rtmt to purge the logs but it is still at 97%.
miket by Level 5
  • 1325 Views
  • 7 replies
Hi,When purchasing UCM 6.0 with 500 seats(LIC-CM6.0-7816=), what does it mean ? does it mean that we can run this UCM 6.0 with 500 IP Phones, in this case no need to purchase DLU ? or do i always need to purchase DLU equal to the number of IP Phones ...
dom.a by Level 1
  • 296 Views
  • 1 replies
