Can't receive FAX
fast5658659
I am having issues with FAX. I am able to send FAX but can't receive it. When I connect analog phone to FXS port I am able to receive call but when I connect fax machine to FXS port  the it wont receive fax.
voice translation-rule 8004
rule 1 /088FAXNumber/ /401/
voice translation-profile INCOMING_FAX
translate called 8004
voice-port 0/0/0
description **FAX machine FXS port**
cptone AU
timeouts ringing infinity
voice-port 0/1/1
description **FXO port**
supervisory disconnect dualtone mid-call
compand-type a-law
cptone AU
timeouts call-disconnect 3
timeouts wait-release 3
connection plar 401
impedance complex1
caller-id enable
dial-peer voice 2500 pots
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2501 pots
translation-profile incoming INCOMING_FAX
incoming called-number 088FAXNumber
direct-inward-dial
port 0/1/1
forward-digits all
no sip-register
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
ephone-dn  6  dual-line
number 401 no-reg both
description AnalogA
name AnalogA
fast5658659
can anyone pls tell me what am missing in the config.. thanks
i can't see any failure in your configuration. Do you hear any faxtone, if you call from outside to the fax maschine?
Please try to configure a second fax maschine and send a fax internal.
Kind regards,
Marcel Ammann
Hi Thanks for reply I can't here anything.. here is the debug voice ccapi inout output
FMC-UC520-VG#
FMC-UC520-VG#
FMC-UC520-VG#
002184: Jan  7 14:56:54.012 ACST: //-1/30A097D0853B/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=401
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
002185: Jan  7 14:56:54.012 ACST: //-1/30A097D0853B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x8794177C, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=401(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2501, Progress Indication=ORIGINATING
FMC-UC520-VG# SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
002186: Jan  7 14:56:54.012 ACST: //-1/30A097D0853B/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
002187: Jan  7 14:56:54.012 ACST: //-1/30A097D0853B/CCAPI/ccCheckClipClir:
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
002188: Jan  7 14:56:54.012 ACST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002189: Jan  7 14:56:54.016 ACST: :cc_get_feature_vsa malloc success
002190: Jan  7 14:56:54.016 ACST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002191: Jan  7 14:56:54.016 ACST:  cc_get_feature_vsa count is 1
002192: Jan  7 14:56:54.016 ACST: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002193: Jan  7 14:56:54.016 ACST: :FEATURE_VSA attributes are: feature_name:0,feature_time:2285774720,feature_id:436
002194: Jan  7 14:56:54.016 ACST: //436/30A097D0853B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=401(TON=Unknown, NPI=Unknown))
002195: Jan  7 14:56:54.016 ACST: //436/30A097D0853B/CCAPI/cc_process_call_setup_ind:
   Event=0x878EE878
002196: Jan  7 14:56:54.016 ACST: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 401
002197: Jan  7 14:56:54.020 ACST: //436/30A097D0853B/CCAPI/ccCallSetContext:
   Context=0x85C34844
002198: Jan  7 14:56:54.020 ACST: //436/30A097D0853B/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 436 with tag 2501 to app "_ManagedAppProcess_Default"
002199: Jan  7 14:56:54.020 ACST: //436/30A097D0853B/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
002200: Jan  7 14:56:54.024 ACST: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
002201: Jan  7 14:56:54.024 ACST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002202: Jan  7 14:56:54.024 ACST: : updating existing feature vsa
002203: Jan  7 14:56:54.024 ACST: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002204: Jan  7 14:56:54.024 ACST:  feature call basic
002205: Jan  7 14:56:54.028 ACST: //436/30A097D0853B/CCAPI/ccCallDisconnect:
   Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
002206: Jan  7 14:56:54.028 ACST: //436/30A097D0853B/CCAPI/ccCallDisconnect:
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
002207: Jan  7 14:56:54.028 ACST: //436/30A097D0853B/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
002208: Jan  7 14:56:57.028 ACST: //436/30A097D0853B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8794177C, Tag=0x0, Call Id=436,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
002209: Jan  7 14:56:57.028 ACST: //436/30A097D0853B/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
002210: Jan  7 14:56:57.028 ACST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002211: Jan  7 14:56:57.028 ACST: :cc_free_feature_vsa freeing 883E2778
002212: Jan  7 14:56:57.028 ACST: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002213: Jan  7 14:56:57.028 ACST:  vsacount in free is 0
FMC-UC520-VG#
FMC-UC520-VG#
you get Disconnect Cause =17. It means that the user / fax is busy.
Please send the config and debug voice dialpeer inout.
Marcel
