06-13-2013 09:57 PM - edited 03-16-2019 05:52 PM
Good day.
I have an issue with transferring incoming call from PSTN. I'm using CME on UC560 platform. Sorry for not posting configuration (too big). Please tell which section should I post to help you understand situation. There are common configuration sections bellow.
Thanks for your help.
06-13-2013 11:42 PM
What issues are you having with transferring calls?
06-13-2013 11:52 PM
The transfer button is not active (grey one)
06-14-2013 01:36 AM
Hi!
Is the ephone-dn configured for dual line ?
Avinash
06-14-2013 01:02 AM
You have to add the key to the ephone-template assigned to the phone and under the telephony-service you have to add the transfer-system full-consult.
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CDQQFjAA&url=http%3A%2F%2Fwww.cisco.com%2Fen%2FUS%2Fdocs%2Fvoice_ip_comm%2Fcucme%2Fsrnd%2Fdesign%2Fguide%2Fclproc.html&ei=3s26UfnuKeu70AHRt4HQCw&usg=AFQjCNHacIm_fPLqGDOOcrTcJAMbxMhzHg
Sent from Cisco Technical Support Android App
06-14-2013 01:45 AM
Have you watched attached file with configuration? The command you suggesting already implemented.
06-14-2013 01:46 AM
Problem solved. It was an error on 8th level of OSI model.
Thank you all for help.
