ā08-01-2014 01:07 AM - edited ā03-16-2019 11:35 PM
Hi all
is it possible to hide internal phone numbers when calling another extension on call manager ?
cheers
Solved! Go to Solution.
ā08-01-2014 04:33 AM
Call routing>tranformation>transformation-pattern>calling party transformation..
Attached is a sample config..
Configure CSSthat has access to the xformation partition on 2222 and uncehck use device pool css
ā08-02-2014 10:04 AM
Ayodeji,
let's look at
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab09/clb09/dialplan.html#pgfId-1583423
A calling party transformation pattern allows the system to adapt the global form of the calling party's number into the local form required by off-cluster networks connected to the route group devices, such as gateways or trunks.
A called party transformation pattern allows the system to adapt the global form of the called party's number into the local form required by off-cluster networks connected to the route group devices.
So, I believe, that a call should go to the gateway/trunk...not to another IP-phone.
Kirill
ā08-01-2014 01:18 AM
Yes it is. You will use calling party transformation. You configure the extension you want to hide, set the calling party presentation to restricted, assign this pattern/extension to a partition. Then configure a calling party xfrom CSS, assign this partition to it. Go to the devices you want to hide the extension from, uncheck use calling party device pool css, and select the css you just created..Bingo! Every call from that number to these devices will have their CLI witheld..Job done!
ā08-01-2014 04:24 AM
Hi There
im stuck on how do do this, could you tell me which pages I need to go into in order?
say I want to hide caller id from 1111 when going to 2222
cheers
ā08-01-2014 05:29 AM
Hello!
It is possible, but you need to use Translation Pattern, not Transformation.
Call Routing->Translation Pattern
Then you configure 2222, and Calling Party Transformation. But you will need to use different Partition and CSS, if you want to use this pattern to hide only spcific DNs.
Transormation Pattern is used while calling outside CUCM.
Kirill
ā08-01-2014 07:08 AM
Kirill..
And who says this cant be done with transformation pattern? Infact that is the best approach as compared to using a translation pattern
Ayodeji,
let's look at
Kirill
ā03-19-2016 08:31 AM
