Cannot disable phoneload-support
Jaro
Could you please help me with this issue:
I have this router:
Cisco C3900e  15.4(3)M3,  with version 10.5 Cisco Unified Communications Manager Express
I´m trying to remove this command
phoneload-support, when I try this I will get:
Error: phonemodel 8831 is already being used by load CLI at <voice register global>, pls remove the references to apply <no phoneload> command
What I should remove ??
global config:
mode cme
source-address 192.x.x.x port 5060
max-dn 75
max-pool 75
load 7821 sip78xx.10-2-1-12SR1-4.loads
load 7861 sip78xx.10-1-1-9.loads
load 8831 sip8831.10-3-1SR2-2.loads
authenticate register
timezone 28
time-format 24
date-format D/M/Y
Thanks for help
R0g22
Do "no load 8831 sip8831.10-3-1SR2-2.loads" first then you should be able to remove the phone-load support command.
R0g22
Thanks for answer, and what this command can cause ? because I have some problem with calls from inside to outside.
Thank you
R0g22
It won't affect your calls. This is write the config file with a phone load. If all your 8831 phones are running "10-3-1SR2-2" firmware, then you should be good. If you add a new 8831 phone, it won't get any firmware info as part of the config file.
