Unable to delete users in Cisco Unity Connection
I am trying to delete voicemail profile but i am receiving error as "object not found user" .
I am using Unity Connection 9.0.1.10000-212. Only for few profiles I am facing this problem
Refer attachment for error
Hi Venkatesh,
Can you try with  below queries:
run cuc dbquery unitydirdb select objectid from tbl_User WHERE DisplayName='Christine Gangi'
run cuc dbquery unitydirdb select * from tbl_globaluser where alias='8360'
Hitesh
6 Replies 6
Deepak Rawat
Refer below thread and perform the suggested workaround:
https://supportforums.cisco.com/discussion/11532786/unable-delete-users-unity-connection
Deepak
Deepak,
I have followed the steps mentioned. But it doesn't work.
1. run cuc dbquery unitydirdb select objectid from tbl_User WHERE DisplayName='dsplayname'
it says no records found
Hi Venkatesh,
Hitesh
Hi Hitesh,
When I use this command it throws the following error
ACE_File_Lock::ACE_File_Lock: Permission denied /dev/shm/CCM_GENstatusLock_0
No records found
This command returned the object Id which I have used to delete the reference.
We have so many profiles which we cannot be to deleted normally. Is there any way we can delete all the profiles at the same time??
What might be possible solution to solve this problem?
Could u delete that entry and how?  I have same issue as u
In the CLI, run the following:
run cuc dbquery unitydirdb SELECT ObjectId from vw_User WHERE Alias = 'alias of the user you want to delete'
Then,
run cuc dbquery unitydirdb EXECUTE PROCEDURE csp_UserDelete (pObjectId = 'objectid from above')
