cannot register cisco 8821 wireless phone on cucm 9.1.2
We have loaded the cmterm-8821.11-0-3-6.cop.sgn file onto all cucm servers and restarted the TFTP services but still cannot add nor register a cisco 8821 wireless phone on the system, any ideas what we can do?
Best Regards
6 Replies 6
At what message is the phone stuck? Also, if you can't add it then you are missing the device pack.
no error message you just can't select the phone model to add nor does it auto register. wanted to get it going without affecting all other phone models as we have very old phones on the system still working on their current fw
Best Regards
Hi Hermanus,
Can you paste "show version active" from you CUCm server for confirmation.
JB
Suresh Hudda
Hi Hermanus,
You had installed phone's firmware file.
You need to install device pack (e.g. cmterm-devicepack9.1.2.16147-1.cop.sgn) on all CUCM nodes and restart the cluster after installation.
Suresh
we will schedule a change request for that thank you very much.
Best Regards
Dear,
It is registered then ? I have the same requirement
