06-27-2012 09:50 AM - edited 03-16-2019 11:53 AM
I am running CME with 7962 phones. When users try to create a conference call they get "unable to connect", this happens the first time the conf button is pressed.
Any ideas?
Solved! Go to Solution.
06-27-2012 10:09 AM
So does it work after the first time?
Does the phones in question have a MRG/MRGL with a conf bridge or are you using software based conferencing on CUCM?
Are these phones in question in the same location or diff locations?
06-27-2012 10:09 AM
07-05-2012 06:46 PM
This feature has never worked.
I am using the CME software version of conferencing.
The feature does not work weather the conference call is initiated to internal or external phones.
My mistake on pushing the "correct answer" button. I still require help with this issue.
07-06-2012 02:43 AM
have you configured conferencing resources on the cme router. Please attach your sh run
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
