04-17-2007 07:39 AM - edited 03-14-2019 09:01 PM
Were upgrading our CCM cluster from v4.1(3) to 5.1(1) and the DMA tool continues to fail with an error stating Validation Failed - CAPF not migrated.
- We do have CAPF configured / installed.
How do we get passed this error?
04-23-2007 06:24 AM
When you upgrade from a 4.x release to a 5.x release and security is enabled on the cluster, you must uninstall the Cisco CTL client that you installed prior to the upgrade,install the latest Cisco CTL client, and regenerate the CTL file. Follow this procedure to
enable security on the upgraded.
04-24-2007 06:42 AM
With security enable on callmanager cluster 4.1(3), is necessary remove CTL client and CAPF before upgrade ? is present a documentation about it ? Thank's
