Captaris RightFax Problem to send/receive FAX with CUCM
d.rocco
Hi all,
as mentioned in subject, i found a lot of problems in deploy Captaris RightFax solution:
The deplyment scenario is the following:
PSTN <--> E1 PRI <--> MGCP Gateway <--> CUCM 7.1.5.32900-2 <--> MGCP Gateway <--> BRI <-->
RightFax is not using FOIP, but is attached to MGCP Router 2811 via 2BRI.
I'm using mgcp t38 fax relay.
Fax is working intermitted and sometimes pages are incomplete!
In attach configurations of 2 MGCP Gateway.
IOS Release is 12.4(24)T4 spservices
Could someone give me help to troubleshooting the problem?
Thank you in advanced
9 Replies 9
kimrobert
How is your rightfax server connected into the network? It should connect via a brooktrout card PRI.
Rightfax is connected via brooktrout card TR114+uP4B (4 BRI) to Cisco 2811 MGCP:
Here the configuration of voice gateway Cisco 2811:
interface BRI0/0/0
description -------------->     to RightFax
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
isdn static-tei 0
isdn skipsend-idverify
interface BRI0/0/1
no ip address
isdn static-tei 0
interface BRI0/1/0
no ip address
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn static-tei 0
control-plane
voice-port 0/0/0
echo-cancel coverage 64
compand-type a-law
cptone IT
voice-port 0/0/1
compand-type a-law
cptone IT
voice-port 0/1/0
compand-type a-law
cptone IT
voice-port 0/1/1
compand-type a-law
cptone IT
ccm-manager redundant-host cucm2-t3 cucm1-t3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server cucm1-t3
ccm-manager config
mgcp
mgcp call-agent cucm1-ant 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax rate 9600
mgcp profile default
This is the deployment scenario:
PSTN <--> E1 PRI <--> MGCP Gateway <--> CUCM 7.1.5.32900-2 <--> MGCP Gateway <--> BRI <--> Captaris RightFAX
You can notice that NO PRI between MGCP gateway and Captaris; there is a brooktrout card TR114+uP4B (4 BRI)
Actualli mgcp gateway is working with T38
Diego
Hi Diego,
I'm doing a implementation with the righFax 9.4 with the CUCM 8.5 and I'm a problem to send and recive the Faxes.
The call arrive until the Gateway and when fax to begin pass, the recive fax fail.
To outgoing Faxes is the same. Follow my topology, I would like if could help me please ?
RighFax (SIP TRUNK)<---------->CUCM8.5 (MGCP) <------------->GW (R2-Digital) <-------------->PSTN <-----------> fax machine
Vinicius
I did not know the new RightFax software could interface via a SIP trunk.
Do you see the gateway receiving the fax call in and forwarding the messaging to the CUCM?
Also what does the configuration on the rightfax SIP trunk look like on the CUCM end (how are you sending the directed fax) as well as the RIghtFax configuration?
In this configuration you do need to enable T.38 on the gateway.
voice service voip
     fax protocol t38 fallback pass-through g711ulaw
ccm-manager fallback-mgcp
MGCP
No MGCP T38 Fax Inhibit
Enable T38 and disable Cisco Fax on the MGCP configuration in CUCM.
In this configuration you wouldn't be using T.38 since the E1 and the BRIs are connected to the same gateway.  Do they fax machine try to negotiate?
ssparkes
Hi, did you get your fax solution working?
Yes I was able to get my fax solution working. I am still using a physical rightfax server with the brooktrout card. The brooktrout card and drivers are largely at fault for faxing problems. It has been solid so far after rebooting the server several times and the reinitializing the brooktrout card.
ssparkes, is there a specific question that you are looking for?
