Castelle Fax Integration with E1 PRI on ISR
I am having trouble integrating Castelle Enterprise Fax Press. I have done the required config on the Router as below:
controller E1 0/3/0
pri-group timeslots 1-16
description <<26_CHANNELS_CONNECTED_TO_FAX_SERVER>>
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn protocol-emulate network
isdn incoming-voice voice
isdn outgoing ie redirecting-number
no cdp enable
dial-peer voice 3960 pots
description <<DIAL_PEER_TO_CASTELLE_FAX>>
destination-pattern 39[678].
fax rate fax
port 0/3/0:15
The Fax is delivered to the Fax Server, but the Castelle guys say that they are not receiving the DNIS.
From the Service Provider, I am receiving 4 Digits and I am sending 4 dgitis to the Dial-Peer 3960.
Is there anything else that I have to send inorder to get this right?
*Nov 20 19:53:32.649: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x2C15
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '026412160'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '3960'
Plan:ISDN, Type:Unknown
*Nov 20 19:53:32.701: ISDN Se0/3/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x
AC15
*Nov 20 19:53:32.797: ISDN Se0/3/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xA
C15
*Nov 20 19:53:32.797: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xE
97F
*Nov 20 19:53:32.821: ISDN Se0/3/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xAC
15
*Nov 20 19:53:32.825: %ISDN-6-CONNECT: Interface Serial0/3/0:0 is now connected
to 3960 N/A
*Nov 20 19:53:32.825: ISDN Se0/3/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref =
0x2C15
*Nov 20 19:53:32.829: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0xE9
7F
*Nov 20 19:53:33.341: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref =
0x697F
*Nov 20 19:53:33.341: ISDN Se0/0/0:15 **ERROR**: call_progress: DEV_CONNECTED VO
ICE ERROR: Bearer capability not available(0x3A): b channel 12 call id 0x3054
*Nov 20 19:53:33.341: %ISDN-6-CONNECT: Interface Serial0/0/0:12 is now connected
to 026412160 N/A
*Nov 20 19:53:49.885: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure wi
th the Power System 2 or this Power System has been turned off.
*Nov 20 19:54:09.885: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure wi
*Nov 20 19:54:13.761: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0
xAC15
Cause i = 0x8090 - Normal call clearing
*Nov 20 19:54:13.765: %ISDN-6-DISCONNECT: Interface Serial0/3/0:0 disconnected
from 3960 , call lasted 40 seconds
*Nov 20 19:54:13.765: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x2C
15
*Nov 20 19:54:13.765: %ISDN-6-DISCONNECT: Interface Serial0/0/0:12 disconnected
from 026412160 , call lasted 40 seconds
*Nov 20 19:54:13.765: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0
xE97F
*Nov 20 19:54:13.773: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref =
0xAC15
*Nov 20 19:54:13.941: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x69
7F
*Nov 20 19:54:13.941: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0xE97F
Thanks & Regards,
Sriharshaa Prabhakar
Senior Network Engineer
Network Services Division
Emirates Computers
P.O.Box 7222, Abu Dhabi, U.A.E.
Phone: +971 2 673 2500
Mobile: +971 50 521 29 56
E-mail: sriharshaa.p@ecead.ae
Web: www.emiratescomputers.ae
paolo bevilacqua
the device disconnecting the call after 40 seconds. What is the problem ?
That call was disconnected by me, it is not disconnecting the call in 40 Seconds, I would like to know is there any way to hardcode DNIS to be sent by Router to the Fax Server?
hauchinango
Level 3
Level 3
Sriharshaa,
Did you get this resolved? I am looking at the Castelle Enteprise Fax appliance and would like any input when interfacing with Cisco Call Manager
