02-19-2017 09:14 PM - edited 03-17-2019 09:34 AM
I have a 2921 as a voice gateway. I have configured e1. When call comes from PSTN, I am getting the following message on the gateway
Plz help
02-19-2017 10:03 PM
That means there is a problem with your call routing, the GW doesn't know how to reach 119, dial peers are missing/wrong, inbound CSS is wrong, wrong or missing digit manipulation, etc.
02-19-2017 10:22 PM
Hi Jaime,
Following are the dial-peers I have created towards CUCM. Can you point it out why my calls are not routed to CUCM?
dial-peer voice 1 pots
trunkgroup ALL_PSTN
description Default inbound dial-peer for calls from PSTN
translation-profile incoming PSTN-to-UCM
incoming called-number 119
direct-inward-dial
dial-peer voice 50 voip
description Inbound voip dial-peer for calls from UCM
session protocol sipv2
incoming uri from ucm
voice-class codec 1
dtmf-relay sip-kpml rtp-nte
no vad
dial-peer voice 100 pots
trunkgroup ALL_PSTN
description E.164 calls from UCM to PSTN
translation-profile outgoing UCM-to-PSTN
destination-pattern +.+
forward-digits all
no sip-register
dial-peer voice 200 voip
description Calls from PSTN to UCM
destination-pattern 119
session target ipv4:10.119.119.1
no vad
02-20-2017 12:35 AM
Dial peer 200 should be able to send the call to cucm for called number 119, also check if gateway CSS configured on cucm for incoming calls has access to the partition of 119.
Manish
02-20-2017 06:34 AM
In case your CSS/PT is correct which is high probability of being your issue as pointed out by others, please post "debug ccsip messages" and "debug voice ccapi inout" for the failed call.
Is 10.119.119.1 your only CUCM server in your cluster? if not, is the SIP trunk on CUCM configured for route on all nodes, if not is this CUCM server listed in the CM Group used by the device pool assigned to the SIP trunk?
02-22-2017 04:47 AM
A bundle of thanks to all who gave me very good suggestions. My problem is solved and the problem was
" I just specified the codec under the dial-peer 200 and it started working. I used g711 and that,s it."
