Cause Value=63 while calling from CME to CUCM
bkhanal1971
Level 3
Level 3
Scenario:
Home lab setup. Site A has a CUCM (CUCM V. 8.6) cluster with 2 servers running on ESXi virtual machines. It has one 3825 router with IOS 12.x, and 2 T1 interfaces.
Site B has a CME router (ISR 2911, IOS 15.x) and 2 T1 interfaces.
Routers in Site A and Site B connect to each other through 2 T1 point to point connections. One interface is configured for ISDN pri and another as an Frame relay. I can ping both FR interfaces from each side, no problem.
Calls (POTS) from one site to another work fine through PRI.
Calls from CUCM site to CME site works fine through PRI
Calls (VOIP) from CUCM site to CME site works fine thorugh FR
However, I have not been able to make VOIP calls from CME to CUCM site.
I have configured SIP trunk, necessary router patterns, partitions, CSS and dial-peer. They all look good.
I have attached the file with the output of the 'debug voip ccapi intout' command. If somebody can point to the problem and a solution, that would be a great help.
Thank you
Khanal
7 Replies 7
acampbell
Khanal
Can you supply the CME config and the number being dialled.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Here is the the Running Config as you requested.
! No configuration change since last restart
version 15.1
service password-encryption
hostname BRANCHCME01
boot-start-marker
boot-end-marker
card type t1 0 1
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name khanal.com
isdn switch-type primary-ni
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 10.0.0.0 255.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice translation-rule 5
rule 5 /.*/ /2028848000/
voice translation-profile DID
translate calling 5
hw-module ism 0
hw-module pvdm 0/1
hw-module sm 1
username admin password 7 152603095438282C6937
redundancy
controller T1 0/1/0
clock source internal
cablelength long 0db
pri-group timeslots 1-4,24
description PRI to PSTN
controller T1 0/1/1
channel-group 1 timeslots 15-24
description FameRelay P2P connection to Branch
ip ssh version 1
translation-rule 1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.11.6.254 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.11.6.254
interface ISM0/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.11.6.253 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 10.11.6.254
hold-queue 512 out
interface GigabitEthernet0/1
ip address 10.11.5.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
ip address dhcp
ip helper-address 10.11.6.254
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface BRI0/0/0
no ip address
shutdown
isdn switch-type basic-ni
isdn point-to-point-setup
interface BRI0/0/1
no ip address
shutdown
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Serial0/1/1:1
no ip address
encapsulation frame-relay
no keepalive
interface Serial0/1/1:1.1 point-to-point
ip address 10.11.7.1 255.255.255.0
frame-relay interface-dlci 100
interface GigabitEthernet1/0
ip address 10.99.99.99 255.255.255.0
shutdown
interface GigabitEthernet1/1
description Internal switch interface connected to EtherSwitch Service Module
no ip address
shutdown
interface Vlan1
no ip address
router eigrp 1
network 10.0.0.0
network 10.11.5.0 0.0.0.255
network 10.11.6.0 0.0.0.255
network 10.11.7.0 0.0.0.255
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:
ip route 10.11.6.253 255.255.255.255 ISM0/0
logging esm config
ixi transport http
response size 4
no shutdown
request outstanding 1
ixi application cme
no shutdown
tftp-server flash:SCCP41.9-1-1SR1S.loads
tftp-server flash:SCCP42.9-1-1SR1S.loads
tftp-server flash:apps41.9-1-1TH1-16.sbn
tftp-server flash:cnu41.9-1-1TH1-16.sbn
tftp-server flash:cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:flash:dsp41.9-1-1TH1-16.sbn
tftp-server flash:dsp41.9-1-1TH1-16.sbn
tftp-server flash:jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:jar42sccp.9-1-1TH1-16.sbn
tftp-server flash:term41.default.loads
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0:23
local-alerting
ccm-manager download-tones
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.11.6.254 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register XCoder
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dial-peer voice 202884 pots
translation-profile outgoing DID
destination-pattern 202884....
port 0/1/0:23
forward-digits 10
dial-peer voice 15099 voip
description VOICE MAIL PILOT
destination-pattern 15099
session protocol sipv2
session target ipv4:10.11.6.253
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 15000 voip
description AUTO ATTENDANT
destination-pattern 15000
no vad
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 601 voip
preference 2
destination-pattern 14...
session target ipv4:10.11.10.248
dial-peer voice 60 voip
session target ipv4:10.11.10.249
dtmf-relay h245-alphanumeric rtp-nte sip-notify sip-kpml
codec g711ulaw
dial-peer voice 62 voip
destination-pattern 82028844004
dtmf-relay rtp-nte
codec g711ulaw
no vad
gatekeeper
shutdown
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 4
sdspfarm unregister force
sdspfarm tag 1 XCoder
no auto-reg-ephone
authentication credential cueadmin The0rch!d
xml user xmladmin password The0rch!d 0
max-ephones 50
max-dn 100
ip source-address 10.11.6.254 port 2000
service dnis dir-lookup
system message BRANCH CME
url services http://10.11.6.253/voiceview/common/login.do
url authentication http://10.11.6.254/CCMCIP/authenticate.asp
cnf-file location flash:
load 7914 S00105000400
load 7906 SCCP11.9-1-1SR1S
load 7960-7940 P00308010200
load 7941 SCCP41.9-1-1SR1S
load 7942 SCCP42.9-1-1SR1S
load 7961 term61.default
voicemail 15099
max-conferences 8 gain -6
call-forward pattern .T
web admin system name cueadmin secret 5 $1$MNLH$A1dP7Q63Jnc.O4aLPBlrv.
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 8
create cnf-files version-stamp 7960 Nov 09 2012 18:29:05
ephone-dn  1  dual-line
number 15000
description Auto-Attendant
name Auto-Attendant
ephone-dn  5  dual-line
number 15005
description Aayusha Khanal
name Aayusha Khanal
call-forward busy 15099
call-forward noan 15099 timeout 10
ephone-dn  10  dual-line
number 15010
description Aryan Khanal
name Aryan Khanal
ephone-dn  11  dual-line
number 2024655568
description Local Number
name Local Number
ephone-dn  12  dual-line
number 19195447040
description National Number
name National Number
ephone-dn  13  dual-line
number 0119779841889957
description International Number
name International Number
ephone-dn  14  dual-line
number 911
description Emergency Number
name Emergency Number
ephone-dn  15  dual-line
number 15015
name Aayusha Khanal
ephone-dn  20  dual-line
number 15020
description Puspa Khanal
name Puspa Khanal
ephone-dn  25  dual-line
number 15025
description MainPhone
name MainPhone
ephone-dn  26  dual-line
number 15026
name Line in Exp module
ephone-dn  62  dual-line
number 19195447041
name Shine Samuel
ephone-dn  97
number 15097.....
mwi on
ephone-dn  98
number 15098.....
mwi off
ephone-dn  100
number 9195441234
description NC Cell Phone
name NC Cell Phone
ephone  5
mac-address E840.40A2.2B5E
username "HQPhone"
type 7942
button  1:5
ephone  25
mac-address 0006.D744.6AA2
type 7960 addon 1 7914
button  1:25 2:11 3:12 4:13
button  5:14 11:26
ephone  61
description Main Phone
mac-address 0026.0B5D.E687
username "MainPhone"
type 7961
button  2:62
line con 0
exec-timeout 0 0
password 7 00301B035449080E4E25
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
flowcontrol software
line 131
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 0 0
login local
transport input telnet ssh
scheduler allocate 20000 1000
ntp master 5
ntp server 64.90.182.55
end
And the number being dialed is 14XXX (14004) which is the number in my HQ Site (CUCM). Branch CME site has the numbes in the 15xxx range.
Thank you.
Khanal
As you have a few ip interfaces on your router I strongly suggest that you bind
one of them for SIP.
voice service voip
sip
bind int g0/0 all
Can you then retest with a sip mesage debug
debug ccsip messages
Alex.
You are awesome and brilliant
Your solved my problem that I had been dealing with for almost a month now. Would you mind elaborating on why my old configuration didn't work?
Anyway, thank you so much for the help even during the weekend!
I give you all the stars possible!
Khanal,
All the voip protocols like SIP,H323 and MGCP all
cause issues of which ip address they select for outgoing ip packets.
As this link states undeterministic selection.
http://www.cisco.com/en/US/docs/ios/12_3/sip/configuration/guide/chapter7.html
When you have multipled ip addresses in a router it is always
best practise to "BIND" the voip protocol(s).
SIP
voice service voip
sip
bind int g0/0
! Obviously you pick a suitable interface
H323
MGCP
mgcp bind control source interface g0/0
mgcp bind media source interface g0/0
mgcp
So you are configuring which IP address will
be used for sourcing voip traffic.
Not leaving it to chance
Hope this helps
Alex.
Great work Alex (+5), keep up the good work.
Response Signature
