CCM 6.0 to CCM 8.0 upgrade
Gingert1976
Hi All,
Sorry if i am being dumb but i currerntly have 6.0 on 2 x MCS7816H3 servers and im proposing to upgrade to CCM8.0 on 2 x new MCS7816I4 servers (i know 8.0 isnt the nest choice but i havnt got a choice on that) the thing is i presume there is a partcode/cost for moving the licenses etc over from the old servers or do i just purchase the 7816I4 with 8.0 on them and away i go!
Jonathan Schulenberg
If you have UCSS coverage, you can place a PUT order and order the servers. If not, you will need to purchase an upgrade.
Also be aware that you cannot directly upgrade from 6.0 to 8.0: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
I know i cannot upgrade directly to 8.0 from 6.0 and i also i need to purchase a upgrade but i cannot find what upgrade to get as
i dont know the part number
Work with your Cisco partner. They will have to place the order for you anyways and have ordering guide documentation for reference to ensure accuracy.
