ccm auto registration
I am using cucm 8.6 I have enabled the auto registration on the PUB but I wanted to use 10 digits number there was a message saying that I can use 8 digits only is there a way to increase the number of digits.
Indeed, I've run into the same limitation, your only option is to come up with non-overlapping 8 DN range.
HTH, please rate all useful posts!
Chris
Karthik Sivaram
Level 4
Level 4
I have checked this Feature and it looks 8 digits is the maximum length can be used with
it. The other way to perform this is use Bulk Administration Tool "BAT" were can use csv
file to be uploaded to CUCM server then phone will be registered.
Hope this helps!
Karthik
thank you so much.
Chris
