CCM installation issue
singh-ashok
We are trying to install CCM 3.3 ( lab purpose) on the following server :
CPU-HP Proliant DL 380G3 X 3.06 GHz
RAM- 1 G.B
HDD- SCSI HDD 146.8 *2
When the Hardware Detection CD is inserted, it gets stuck after sometime. We have tried 2 different CD packs, same result each time. These CD's work fine on other hardware.
Someone changed the RAID settings / removed a hard drive some time back. Can that be a cause?
Chris Deren
This server is too new to work with CM 3.3 and any of the OS supported on that version i.e. 2000.2.7, you will either have to get a supported server for that version of CM, or install newer software.
Chris
Thanks Chris for your valuable input. Have a nice day.
Abhijit.
