03-20-2012 08:26 AM - edited 03-16-2019 10:13 AM
Dear All,
Is it possible to configure format of CDR records produced by IOS gateway like as CDR records with CallManager?
Many thanks for any help.
03-20-2012 09:20 AM
You can change the level of detail within the data by using the detailed / compact template or create your own using the acct-template command and upload your own template to the router.
Standard template details info - http://www.cisco.com/en/US/docs/ios/voice/cdr/developer/guide/cdrcsv.html#wp1049440
Custom template info - http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide_chapter09186a00800b5de4.html#1046919
Note, RADIUS and FTP contain all the CDR header values, Syslog does not.
Hope this helps.
Remember to vote if you find this useful.
Log in to Community
