12-21-2016 09:40 PM - edited 03-17-2019 09:00 AM
Hi Team,
We are running CUCM System version: 11.0.1.20000-2. When I pull CDR report data it contains data only till 10 am. All suggested configuration looks fine in cucm . Kindly help. PFA warning CDR message missing today's data.
12-21-2016 10:34 PM
Is the CDR data till 10:00 AM on a daily basis or is it only for today? Were the reports working fine earlier? Can you check if CDR's are being created an processed properly as per the following doc
https://supportforums.cisco.com/document/55821/troubleshooting-cdr
Manish
12-21-2016 10:52 PM
Hi Manish,
Thank you for your prompt reply .
There were data missing in each day report for multiple extensions . and no data available from yesterday 10 am on wards for all extensions . Issue has been resolved when I followed below procedure .
swathy
