CER on VM
jamesalston
Hi can can anyone tell me if Cisco Emergency Responder is supported in a VM enviroment?
2 Accepted Solutions
Jaime Valencia
No, 8.0 is the latest one and this are the supported platforms.
Table 6     Supported MCS Platforms
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cer/8_0/English/release/notes/cer_801.html#wp41370
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
htluo
Level 9
Level 9
It depends on the definition of "support" and the CER version.
On UC (Unified Communication) 8.x, VMWare is supported.  However, depending on individual products, it may or may not be stated (clearly) in release notes or compatiblility guides.
On pre-8.x version, you may install CER on VMWare.  It will work with some tuning.  But it's not supported by Cisco TAC.
See: http://htluo.blogspot.com/2009/07/cisco-software-on-vmware.html
Michael
Jaime Valencia
java
java
Thank you
htluo
Level 9
Level 9
Michael
Thanks for the confirmation.
