Certificates CUCM, IMP & CUC version 11 installation?
Hamad ghathber
Hello
  We have issue with certificates in CUCM, IMP & CUC.
We have 3 CUCM  Servers: 1 Pub, 2 SUB and 2 IMP, version 11
Also, we have 2 CUC Servers, version 11
We are using CA (internal windows server)
Question 1: what is the impact if the certificates expired?
Question 2: what is the certificates needed between CUCM & CUC?
For CUCM:
callmanger
callmanger-trust
callmanger-ECDSA
tomcat
tomcat-trust
TVS
The above certificates are going to expired soon.
What is the different of the above certificates and usage?
For CUC:
callmanger & tomcat are already expired.
How to regenerate the certificates ?
Is there any dependencies?
Thanks in advance
Chris Deren
Have you read this:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/11_5_1/secugd/CUCM_BK_SEE2CFE1_00_cucm-security-guide-1151.html
Dont let your certs expire, are all of the certs you listed signed by CA or are some self signed as typically only Tomcat, and possibly CallManager certs on CUCM get signed by external CA.  For IMP XMPP would be another one.
For CUC to UCM connectivity the only reason to exchange certs would be if you are doing encryption to voicemail or if you are using PIN sync between the apps (available in 11.5+).
Thanks for your reply
I am sorry , I am little bit confused.
My question is :
once i generate CSR (for any cert such as TVS) then send it to CA to sign it, How many signed certificates i must received to upload to CUCM?
Quiestion 2:
which certificates should uploaded as (TVS)?  or (TVS-trust) ?
This is consider as identity certificates?
Thanks again
>> You can get a signed cert for each type of cert, i.e. tomcat, call manager, TVS, IPSec, etc. Some can be signed by CA, others can be left as self signed based on your requirements.  You can either generate CSR on each node, or if you are on relatively new CUCM (10.5+ I believe) you can get multi-san CSR that addresses all nodes with single SAN cert.
Quiestion 2:
Signed cert goes into TVS/tomcat/etc, root and intermediate certs need to be uploaded into -trust stores.
