CFA is successfully set, but call to it failed
saviolabao2
Hello All,
We are running CUCM 8.5 and we meet a problem here:
We have a Phone (let's name it P_A) in site A, we set CFA of this phone to a external mobile, then the result is as below:
1. Call internally from Phone_B in site A -> OK
2. Call internally from Phone_C in site B -> Busy tone
3. Call from external mobile -> Busy tone
We also tried to set CFA to Phone_D in site A, the problem is still the same.
Does anyone have any idea about this?
Thanks.
Savi
Manish Gogna
Hi Savi,
You can start by taking a debug from the gateway through which the call is forwarded to External Number ( CFA destination ). For SIP or H323 you can enable the following debugs
debug voice ccapi inout
debug ccsip messages
( Take the debugs when there is less activity on the gateway )
If the call does not even reach the gateway then the issue is most likely on cucm config, else the debugs will provide some details on why the forwarding fails.
Manish
- Do rate helpful posts -
