CFA Not Working
Oussama.bachiri
Hi everyone,
firs let me explain the situation
Requirement:
x2 IP Phones
x2 User Device Profile
Partitions:
PRT-LOCAL
PRT-NONE
CSSs:
1xCSS_NONE = {}
1xCSS_LOCAL={PRT-LOCAL}
Scenario:
Phone A Line is in PRT-NONE, The Phone is in CSS-NONE
Phone B Line is in PRT-NONE, The Phone is in CSS-NONE
Phone A can't call Phone B and vise versa
with did this so users have to loggin to be able to call.
Good!!
Scenario : (Login with the User Device w/ EM)
UDP A Line in PRT-LOCAL and CSS Line is CSS_Local
UDP B Line in PRT-LOCAL and CSS Line is CSS_LOCAL
Phone w/ UDP_A calls Phone w/ UDP_B !GOOD
Phone w/ UDP_A Transfer call to Phone w/ UDP_B !GOOD
Phone w/ UDP_A Conference w/ Phone w/ UDP_B !GOOD
Phone w/ UDP_A Forward ALL to  Phone w/ UDP_B !NOT GOOOD
Why is the Forward ALL not working!!!!
Please Help, thank you.
Hi.
On directory number configuration on UDP, can you please check the CSS activation policy on the call forward section.
Try to configure it as "With CSS configured" and select a valid CSS next to Call Forward All field
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
Carlo
Hi man , thanks for the reply.
the policy is left as default i will change it and let you know
