CFB and XCODE doubt
I am with very very doubt about like cfb and xcode work.
First.
My customer need a conference with 18 people (meet me), so to this, I'm using CFB (of CCM/software).
On MRG there are: one CFB(CCM), one CFB(hardware/router).
So, the MRG use the first CFB on list. How can I do to select what CFB must be used? When meet me I like CFB(CCM) to others I like CFB(router)?
Peterson
only audio CFB, that's why video endpoints need a separate MRGL which has video in 1st place. unless using 7.X of course, 7.X will choose the video conference if the parties are detected as video enabled
java
if this helps, please rate
java
7 Replies 7
Jaime Valencia
if they're in the same MRG you can't, they're used in a round robin fashion.
the way to choose them is to split them in separate MRG and then add them to MRGL in the order you want to use them
java
java
But with MRGL and 2 MRG (round robin). 50% of meet me will use CFB(hardware).
Another situation.
I have CFB(router or software) and a MCU Cisco (CFB too). So I want that videoconferece use CFB of MCU and when conference call use CFB (router or software)
Peterson
that's only possible if you have CUCM 7, it introduces intelligent bridge selection exactly for that. any previous release will work the same as i explained, <2 CFB in same MRG = round robin
java
java
Hi Java.
So, if I have a MRGL with 2 MRGs and the resource of the first fail. The second MRG will be used? This apply to CFB and XCODE? Like Route List and Route Group?
Peterson
precisely, if it fails or already has all the resources in use then it checks the next MRG available and so on until it exhausts all options
java
java
Hi Java
Thank you very much!
A last question about it (i think).
2 MRGs
1º MRG with CFB (CallManager)
2º MRG with CFB (MCU Cisco)
1 MRGL with MRG 1 and 2.
So, I need a videoconference. The CallManager will try the 1st MRG (cfb/ccm). The conference will closed with audio just or the MRGL will try the 2nd MRG with MCU Cisco?
Peterson
java
java
