IP Telephony and Phones
Labels
hello, On some of our XP computers, the ciscotsp001 fails to show up as a provider (phone and modem options) after installing version 6.1(2.4). Doesn't matter if its an upgrade or fresh install. Any ideas? Thanks in advance..
trimetal4 by Level 1
  • 564 Views
  • 3 replies
Hello netpro'sStrange problem here, I have just upgraded CM 4.1.3 to 7.0.1 and the only problem I have is to do with a CTI RP.The old CM 4.1 system had a CTI RP that had a directory number associated to it, this directory number had a CFA to a hunt p...
Hi I have a CCME version 7 installed, the problem is that the music on hold only is heard from the pstn caller, the music on hold in the internal phones registered in the call manager express is not heard. Why ?telephony-service moh music-on-hold.au
I'm trying to build a lab VMWare 7.0(1) system to check out some features, its not a production system.I've built many 5.x and 6.x VMWare systems that have always gone fine.When I try an upgrade from 6.x to 7.0(1) it always results in a failure to re...
billybjo1 by Level 3
  • 625 Views
  • 4 replies
Hi, is there any way to upgrade CCM 6 to 7 such that all licenses upgarded automatically? or something such as export licenses and importing to new installation? my problem is that i don't have any info like PAK or serial number of my license on CCM ...
I am troubleshooting voice issue in a call center, there is some delay on Hybrid Voip to the operator work station. I am using Cisco AS5350 VG for voip that is connected to a cisco WS-C2950C-24 where all the workstation are plugged in to.How I can ...
I am Having a issue accessing Unity System Administration.1.) I can accesss via RDP but System Admin is not in the Program\Unity folder, it does appear on the menu bar under the Cisco icon. However, it will not take my credentials. Shouldn't "System ...
jcsmith96 by Level 1
  • 372 Views
  • 1 replies
