04-15-2021 01:00 AM
Dear All.
I have trouble with identifying by name for incoming connections comming from siptrunk. We have two PBX connected, Cisco CME - for desk phones (SIP Phones only) and Uniify OpenScape Business V2 for DECT calls. The problem is that Unify PBX only transmits the number (3 digits) via SIP-Trunk and this is displayed on the phone. I would like the name to be displayed. We have no chance to set it on Unify PBX. Below is a typical SIP header during an internal call from 551 to 524.
Can I configure Cisco CME to substitute the string - warehouse - instead of 551, even though it is an incoming call from another PBX ?
Apr 15 07:09:59.970: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:524@10.33.99.221:5060 SIP/2.0 Via: SIP/2.0/UDP 10.10.12.10;branch=z9hG4bK2479242e13c932bc4;rport Max-Forwards: 70 From: 551 <sip:551@10.33.99.221>;tag=4e8d957fb0 To: <sip:524@10.33.99.221> Call-ID: 9800750db570e686 CSeq: 1822707770 INVITE Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, INFO, UPDATE Contact: <sip:551@10.10.12.10> P-Asserted-Identity: <sip:551@10.33.99.221> User-Agent: OpenScape Business M5T SIP Stack/4.2.12.14 X-Siemens-Call-Type: ST-insecure Content-Type: application/sdp Content-Length: 324
Full SIP log attached as a file
Solved! Go to Solution.
04-15-2021 02:11 AM - edited 04-15-2021 04:04 AM
Yes that is possible. For this you would need to use a SIP profile used in the inbound direction on the SIP trunk to the CME from Unify. Please note that it would need do this per directory number, so it's not a very scalable solution. See below for an example for the number given.
voice class sip-profiles 200 request ANY sip-header From modify "From: 551 (<sip:.*@.*>)" "From: Warehouse \1"
response ANY sip-header From modify "From: 551 (<sip:.*@.*>)" "From: Warehouse \1" ! voice service voip sip sip-profiles inbound ! dial-peer voice <tag> voip voice-class sip profiles 200 inbound
You can test this with the SIP profile tester at this link.
04-21-2021 10:19 PM
Thank you Roger - you answer was very useful, my problem is fixed !
04-21-2021 10:45 PM
Glad to hear that and thank you for your letting us know that it worked for you.
10-06-2022 01:50 AM
we have cme on 2951 that serves both IP and analog phones, with IP phones everything goes fine regarding caller name, but if we make a call from an analog to an IP phone only a number appears, can we add a name to the analog phone to have appeared as caller id.
10-06-2022 03:35 AM
ahmed.taha@zfod.eni.com Advice you to create your own post to ask your question as this one is marked as solved and your question is somewhat off topic to the OP.
