Change Caller-id from SIP-TRUNK CME
Dear All.
I have trouble with identifying by name for incoming connections comming from siptrunk. We have two PBX connected, Cisco CME - for desk phones (SIP Phones only) and Uniify OpenScape Business V2 for DECT calls. The problem is that Unify PBX only transmits the number (3 digits) via SIP-Trunk and this is displayed on the phone. I would like the name to be displayed.  We have no chance to set it on Unify PBX. Below is a typical SIP header during an internal call from 551 to 524.
Can I configure Cisco CME to substitute the string - warehouse - instead of 551, even though it is an incoming call from another PBX ?
Apr 15 07:09:59.970: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:524@10.33.99.221:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.12.10;branch=z9hG4bK2479242e13c932bc4;rport
Max-Forwards: 70
To: <sip:524@10.33.99.221>
Call-ID: 9800750db570e686
CSeq: 1822707770 INVITE
Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, INFO, UPDATE
Contact: <sip:551@10.10.12.10>
P-Asserted-Identity: <sip:551@10.33.99.221>
User-Agent: OpenScape Business M5T SIP Stack/4.2.12.14
X-Siemens-Call-Type: ST-insecure
Content-Type: application/sdp
Content-Length: 324
Full SIP log attached as a file
Yes that is possible. For this you would need to use a SIP profile used in the inbound direction on the SIP trunk to the CME from Unify. Please note that it would need do this per directory number, so it's not a very scalable solution. See below for an example for the number given.
voice class sip-profiles 200
 request ANY sip-header From modify "From: 551 (<sip:.*@.*>)" "From: Warehouse \1"
response ANY sip-header From modify "From: 551 (<sip:.*@.*>)" "From: Warehouse \1" ! voice service voip sip sip-profiles inbound ! dial-peer voice <tag> voip voice-class sip profiles 200 inbound
You can test this with the SIP profile tester at this link.
Response Signature
5 Replies 5
Response Signature
Thank you Roger - you answer was very useful, my problem is fixed !
Glad to hear that and thank you for your letting us know that it worked for you.
Response Signature
we have cme on 2951 that serves both IP and analog phones, with IP phones everything goes fine regarding caller name, but if we make a call from an analog to an IP phone only a number appears, can we add a name to the analog phone to have appeared as caller id.
ahmed.taha@zfod.eni.com Advice you to create your own post to ask your question as this one is marked as solved and your question is somewhat off topic to the OP.
Response Signature
