Change Language to Arabic CallManager Express
moussa.malqui1
Hi All,
I use CME Version 15.5(1) T2. I uploaded file language po-locale-ar_MA-k3-10.3.2.1000-1.cop.sgn in
Flash: from TFTP server, after I type "user-locale 1 u1 load
po-locale-ar_MA-k3-10.3.2.1000-1.cop.sgn" i had this problem "% Invalid input detected at '^'
marker" the marker is under 1. where is the problem ?
Thank you in advance
Nadeem Ahmed
Moussa,
seems like you are using the wrong locale file for CME. it suppose to be .tar file not cop.sgn
Download the correct locale from cisco.com for CME
http://www.cisco.com/cgi-bin/tablebuild.pl/CME-Locale
upload the file using TFTP to flash:
Extract the .tar to flash
Under the telephony-service
user-locale 1 ===
network locale
no create
create cnf
Please use this reference link how to upload and run locale on CME
https://supportforums.cisco.com/discussion/10821846/how-chargue-locales
Br,
Nadeem
PS: PLease rate all useful post.
Br, Nadeem Please rate all useful post.
thank you Nadeem
Rajan
Hi Moussa,
COP.sgn is for CUCM. you need to download the locale files for CME from the below link and uncompress the files. Then copy that to the flash and use the same.
https://software.cisco.com/download/release.html?mdfid=277641082&softwareid=282897001&release=10.5&relind=AVAILABLE&rellifecycle=&reltype=latest
Rajan
thank you rajan
