Change the order of name in Corporate Directory
Dear all,
The format of the name of user shown in Corporate Directory is lastname, firstname. For example : Wang (lastname), Bill (firstname). How to change that order? So that the name shown is firstname, lastname. I'm using CUCM 7.1.5. Does anyone know how to do this?
Thanks.
Hi Triandi,
Please check under CUCM - System - LDAP - LDAP Directory - Select the LDAP directory - User Fields To Be Synchronized
You should be able to swap the CUCM - LDAP fields here
Hi deepak
Thank you for you reply. I'm using local directory in CUCM, not using LDAP. Do you have any idea about this?
nitsinha
Level 4
Level 4
Chek this thread out. May be of some help
https://supportforums.cisco.com/message/3025971#3025971
Nitesh
PS:Pl rate helpful posts
