Changing Button Template in CUE/CME
Robert Dempsey
I have a 7960 with a 7914 sidecar. I'd like to configure one of the six line buttons on the 7960 as a speed dial for paging, but I can't find any hint as to how to do this from the CLI. The GUI certainly doesn't appear to allow it. Presently all the line buttons are configured as lines, but not all are associated with DNs. This is on a CUE 3.1 system.
Is there any good instruction on changing the phone button template from the CLI?
Manish Gogna
Hi Robert,
Please check the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmespeed.html#pgfId-1011116
Manish
- Do rate helpful posts -
Thanks for responding, Manish!
I tried that and had no good result. The speed dial still isn't showing on the phone. The first 5 lines on the 7960 and all 14 lines on the 7914 sidecar are all configured as lines. The 6th line on the 7960 is where I want the paging speed dial, but it's not showing up. Could it be that the template has it configured as a line and not a speed dial, or is this auto-configured?
Hi Robert,
You can set the button layout as shown in the link below;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr/cme_b1ht.html#wp2229911260
Cheers!
Rob
