Changing called number based upon calling number
iptuser55
Level 6
Level 6
I  need to present different number to the original number.   I know I can do this by external mask but is there another neater way?
DN 5551234
Calls 911
Outbound need to show  2221000 to 911 instead of 5551234
DN 5551234
Calls a normal number say 6104545
Outbound to show 5551234 to 6101234
I don't want to use different route patterns or lots of partitions
Also we  use RLG as well, so my idea is to  use a single route pattern 911, then use calling transformation to capture the different calling DN and then change the calling DN based upon that number
8 Replies 8
R0g22
If you are using a CUBE and/or a SIP trunk to your GW, it is much easier to it there rather than on UCM IMO.
Thanks for the reply
The DN's making call will from different sites and the modified number will different per site
Site A
Dn555xxxx
Make a normal call then their ddi is sent
Make a 911 then the sited.  number ie 2221000
Site B
DN 444xxxx
Make a 911 then  the sites number 6121800
Cube Config
change the sites  911 to say 555911 in cucm then route to cube and set up a dial peer  of destination pattern 555911 then send Site A 2221000
Same with site B  change outbound to 444911  dial peer destination 444911 send out site B 6121800
I guess this can or is there a better way in cube or better to do it in cucm  ?
Hi You can do it in this way
create voice translation rules and place them on the Emergency numbers dial peer, if you are using standard local route groups for emergency dialing this is the way to go so that you don't have to create any additional partitions or patterns for example
Voice translation profile
Voice translation-profile Emergency
translate calling 400
Voice translation rule
Voice translation-rule 400
rule 1 /555....$/ /2221000/
rule 2 /444....$/ /6128100/
Dial peer
Destination-pattern 9911
forward-digits 3
translation-profile outgoing Emergency
We have a centralised PSTN cube set so the GW approach works though we also have standalone GWs as well so we can replicate the same setup with GW.
I worked for a company where we did the following
SiteA site code 444
Route Pattern 9.911 PT_911_SITEA
Device CSS contains pt_911_SITEA
TP 9.911
Translate to say *9.911
Route Pattern *9.911
Use Device Pool calling transformation
Calling Transformation PT_SITEA
 444XXXX-PT_SITEA
transform to 2123331000
If my memory is correct- has anyone used this method- pro`s and con`s
thanks
Device pool level transformation will affect all calls for the devices using that device pool, or you have to create 911 route patterns for each site and add the calling party transformation mask from the route pattern level, the problem with this approach you will have multiple 911 patterns in different partitions. Not sure in your config why you have a route pattern and translation pattern with same 9.911
The multiple route pattern are
User dials 9.911 -these are example digits
Which is a TP for siteA
TP translates this to *9911
Route pattern *9911
This is set to use the calling  transformation of the device pool and a css of
css-siteA-XForm
Pt-911
We assign all logged DN's of site A to pt-911 eg logged out devices 444xxxx
Where the calling DN matches then change the outgoing CLI if site A
If the DN doesn't match then don't change outgoing cli
This is from memory. It looks like the cube approach us better but is there a better way using xform patterns
If you are talking specifically about altering callerID for emergency (911) calls, and you are using CUCM 11.0 or later, have you looked at implementing the native Emergency Call Handler available in that version?
The upshot is that you can assign ELINs on a per-Device Pool basis. And Device Mobility will allow roaming users to pick up the ELIN on their roaming device pool.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200452-Usage-of-Native-Emergency-Call-Routing-F.html
