Changing cluster security mode
techguy
Level 4
Level 4
We have 3 subscribers, 1 publisher, 1 CUPS and CUC. Do I need to change security mode in all servers of cluster or only in publisher?
Thanks.
CesarTrombeta
It should be for all servers in the cluster. Or you could use CUCM in the Mixed Mode:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/11_0_1/secugd/CUCM_BK_C1A78C1D_00_cucm-security-guide-1101/CUCM_BK_C1A78C1D_00_cucm-security-guide-1101_chapter_01.html
You also can find useful information on the Solution Reference Design Guide for UC Applications versions you are running.
Example: Cisco Collaboration System 12.x Solution Reference Network Designs (SRND)
Jaime Valencia
https://youtu.be/0FDABxcBLy0
java
if this helps, please rate
