05-17-2018 10:01 AM - edited 03-17-2019 12:50 PM
Hi experts, we have an requirement to change the CUCM IP address, the environment has 1 x cucm pub, 1 x cucm sub and Unity. Understand that we need to change the publisher IP first, followed by subscriber and trunk config. Apart from taking DRS backup, is there anything else that needs to be taken care? Thanks
05-17-2018 10:20 AM
Make sure to read the documentation on the change to make sure you have the proper procedure, then update any references to that IP (DNS, DHCP, configuration, etc.) in your environment.
05-17-2018 12:15 PM
Hi there
Yes, make sure you read the CUCM IP Address change documentation well enough and try to do it on a lab network if you have access to.
CUCM
CUC
Just to keep a note of these points before the change,
show perf query class "Number of Replicates Created and State of Replication"
The state should say “2”
Good luck !!!
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
06-08-2018 12:33 AM
Hi there, do i need a New license file ?
