06-07-2011 11:56 AM - edited 03-16-2019 05:19 AM
Hello guys,
I would like to request support since i can't get the calling number change to a certain
number that i want.
Example:
extensions 2307, 7760, 2362 and 2385 when calling all other extensions will have to be
presented as 7877 on the called display.
I already have tried translation patterns and calling party transformations.
thanks in advance.
Filipe Quintela
06-07-2011 12:22 PM
You're correct to be using calling party transformations. Did you set the Calling Party CSS on the destination device, since that's what CSS will be used to reach the calling party transformation patterns?
06-07-2011 12:26 PM
Translation patterns are the way to go, if it's not working then most likely it's a configuration problem with the CSS and partitions. You'll have to review your config to make sure those phones reach the TP, and the TP can reach the end DNs you want to reach.
Most likely the CSS from calling devices is wrong and you're allowing it to reach the end devices and not only the TP.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
