changing the preference of dial-peers under call-manager-fallback
Osama Mahmoud
Is it possible to change the preference of the dial-peers created for ip phones when the site is in srst ?
Chris Deren
No, but what is your reasoning for needing this?
HTH,
Chris
Gergely Szabo
dynamically: no.
However, if you want to modify dial-peer hunting, the dial-peer hunt command is for you.
G.
The problem is that I have a 8961 phone , this phone has a shared line with a 8945 phone , when the site goes to srst I have configured an alias command for a number to go to this shared line . The problem is this scenario never works neither of the phones ring . I thought of lowering the preference of the dial peers which are created by call-manager-fallback so I give higher preference for the 8961 line .
It could be the shared line feature dont work with call manager fallback, as it is limited.
Please rate if this helps
