04-14-2014 09:09 AM - edited 03-16-2019 10:27 PM
I have CIPC 8.6 installed on Win 7 laptop using Cisco VPN into the company. I can not get it to register. It just keeps saying configuring IP...
Help needed.
Solved! Go to Solution.
04-14-2014 11:25 AM
04-14-2014 10:55 AM
Have you already verified you can reach CUCM, and basic connectivity??
That your VPN has routing to CUCM??
04-14-2014 11:15 AM
IT does download the CTL file from the CUCM but then nothing.......
04-14-2014 11:19 AM
Can you download the phone's config file via a TFTP client on the same PC while connected to the VPN?
04-14-2014 11:25 AM
I dont know. I dont have a TFTP client on my laptop.
04-14-2014 11:33 AM
Install one then?
04-14-2014 11:25 AM
