09-16-2011 05:53 AM - edited 03-16-2019 07:01 AM
Hi guys,
I configured a Cisco 1751V, with two-VIC-2BRI NT / TE, in order to use it as a test device, IOS version "ip voice 12.4T(15)".
I have a vic configured as "network side", the other VIC I configured as a "user side": I then I connected through a cross cable isdn.
I configured the router properly (BRI interfaces, tdm clock, voice ports, dial-peer): the problem is the "power line", and both the ports used (one for each vic) are been "deactivated" (L1 State F3) when I placea call.
It 'can this setup on one router? What is meant by "phantom power"?
thanks
09-16-2011 08:02 AM
Francesco,
For testing in a lab connecting betwwen the cards should be OK
Your NT side should use something along these lines:-
interface BRI0/0
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
no isdn outgoing display-ie
isdn static-tei 0
isdn skipsend-idverify
Your ST side should use something along these lines:-
interface BRI1/0
no ip address
isdn static-tei 0
What do you see when you issue
show isdn status
I think if the lins are always showing as L1 deactivated then the issue is the cable.
NT SIDE ST SIDE
3 -------------------------- 5
4 -------------------------- 6
5 -------------------------- 3
6 -------------------------- 4
Alex
09-19-2011 06:44 AM
thank you.
You've reported same configuation that i used.
09-19-2011 07:01 AM
Francesco
Have a read at this document.
Seems you need to shut the interface then apply the config in a set order.
I must admit that I never had to use the line-power command for the UK.
Alex
