Cisco 2801 CCME
mdraveisau12345
I just need some clarification on one thing :- We have a 2801 Router with Call Manager Express configured. If we backup the router configuration files onto flash. Insert the flash onto another 2801 router and then load configuration from flash shouldn’t be a problem???
Chris Deren
Yes it will work fine as long as all cards are in same slots.
Chris
