Cisco 2811 connect to DMS 100
rastitt
Level 4
Level 4
I was wondering if anyone has used a cisco 2811 as a gateway. That is connected to a nortel DMS 100 via pri. Then out of the cisco 2811 go to a poe switch and then to a phone and make a call... I would like some help on this if possible... Thanks
dmotloch
We've done this -- what kind of problems are you having?  Can the DMS do QSIG or just DMS100?
Your 2811 - is it MGCP with Call Manager?
Let me know some details of the troubles you have and your config.
Well we are not doing it through our cm. We are wanting to just make a sip phone register with the 2811 if that is possible. Then just send a pri to the 2811 that will allow numbers in the tdm switch be used. The 2811 is just like a manager to know what dn is associated with what ip address... If that makes any sense...
