Cisco 2811 max sip sessions
peterzork
We have a situation where we have 2 2811 routers configured to receive calls from several sip providers and forward them to a pbx on the LAN by also using SIP.
Coded is the same , incoming g729r8 and goes out to the pbx with g729r8 .
For example when below statistics reach this numbers the router cpu is almost at 98% .
   Number of SIP User Agent Client(UAC) calls: 45
   Number of SIP User Agent Server(UAS) calls: 45
Now my question is this really the maximum for this type of router ?
Many thanks!
Kind Regards,
Peter
paolo bevilacqua
Wrong forum, post in "voice - IP telephony". You can move you post using the actions panel on the right.
