cisco 2900 sip trunk
sokolmukaj
Im trying to configure a sip trunk with my isp on a 2900 series. Need help
Add the following:
voice service voip
no ip address trusted authenticate
Chris
18 Replies 18
paolo bevilacqua
Maybe hire a reputable consultant or certified partner ?
timon.huber
Timon i did try that configuratio example and im familiar with cisco voice configurations. but im not understanding the problem with the connection to the isp since no packets are being sent when incoming call is sent to my router
timon.huber
is your router registered on ISP registrar?
NAT, Firewall settings are correct?
Give us more informations, Post some debugs
Chris Deren
What iOS version are you using? You may be running into VoIP authentication feature blocking the traffic.
ios 15.1, i managed to make outgoing calls by fixing config errors ondial peers and translation rules. Now i created a translation rule for incomig calls using called number and i dont get any calls outside the trunk ( fast busy signal)
Please post your config.
Chris
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  bind control source-interface GigabitEthernet0/1.208
  bind media source-interface GigabitEthernet0/1.208
  registrar server
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 172.20.100.1 port 5060
max-dn 30
max-pool 30
create profile sync 0065402769141141
voice register pool  13
id mac 2C41.3816.6880
number 1 dn 13
preference 1
no call-waiting
codec g711alaw
voice translation-rule 1
rule 1 /35552901060/ /140/
voice translation-rule 3
rule 1 /35552901060/ /150/
voice translation-rule 10
rule 1 /^.*/ /35552901060/
voice translation-rule 101
rule 1 /^0\(.........\)/ /355\1/
voice translation-profile CEL-DNIS-XLATE
translate called 101
voice translation-profile INTERNATIONAL-TP
translate called 1001
voice translation-profile SIP-IN
translate called 3
voice translation-profile inboundTrunk
translate called 1
interface GigabitEthernet0/0.100
description "Voice VLAN Interface"
encapsulation dot1Q 100
ip address 172.20.100.1 255.255.255.0
dial-peer cor custom
name TIRANA
name INTERURBANE
name MOBILE
name INTERNATIONAL
dial-peer cor list NO-ACCESS
dial-peer cor list CALL-TIRANA
member TIRANA
dial-peer cor list CALL-INTERURBANE
member INTERURBANE
dial-peer cor list CALL-MOBILE
member MOBILE
dial-peer cor list CALL-INTERNATIONAL
member INTERNATIONAL
dial-peer voice 2 voip
description *** Incoming call to  - -- Generic -- - SIP Trunk ***
destination-pattern 0T
session protocol sipv2
session target sip-server
incoming called-number .T
dtmf-relay sip-notify
codec g729br8
dial-peer voice 20 voip
translation-profile incoming SIP-IN
redirect ip2ip
incoming called-number .%
codec g729br8
dial-peer voice 1 voip
description incoming SIP Trunk
redirect ip2ip
translate-outgoing calling 10
incoming called-number 35552901060
codec g729br8
sip-ua
credentials username xxxxxxx password 7 xxxxxxx realm xxxxxx
authentication username xxxxxxxxxxxx password 7 xxxxxxx
calling-info pstn-to-sip from number set 35552901060
no remote-party-id
timers connect 100
registrar ipv4:80.78.66.70 expires 3600
sip-server ipv4:80.78.66.70
gatekeeper
shutdown
telephony-service
max-ephones 24
max-dn 30
ip source-address 172.20.100.1 port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Jan 11 2012 18:15:56
part of voice config and sip trunk
debug ccsip  calls messages
SIP Call statistics tracing is enabled
Jan 17 20:27:43.311: //13240/571F11647758/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x2CD73768
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           :
Called Number            : 35552901060
Source IP Address (Sig  ): 192.168.207.77
Destn SIP Req Addr:Port  : 80.78.66.70:5060
Destn SIP Resp Addr:Port : 80.78.66.70:5060
Destination Name         : 80.78.66.70
Jan 17 20:27:43.311: //13240/571F11647758/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g729br8
Negotiated Codec Bytes   : 20
Nego. Codec payload      : 18 (tx), 18 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.207.77
Source IP Port    (Media): 25666
Destn  IP Address (Media): 80.78.64.16
Destn  IP Port    (Media): 21338
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 21
Disconnect Cause (SIP)   : 403
Jan 17 20:27:43.655: //13241/B7806B4D174E/SIP/Call/sipSPICallInfo:
Calling Number           :
Jan 17 20:27:43.655: //13241/B7806B4D174E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17616
Destn  IP Port    (Media): 21340
Add the following:
voice service voip
Chris
after adding the line the phone company says the dialed number is not correct
Can you post the SIP debug for the call?
is your epone-dn defined as DN 150?
Can you also post debug voice dial-peer?
Chris
ephone-dn  1
number 150
label koli
ephone  1
device-security-mode none
mac-address 0005.9A3C.7800
type CIPC
button  1:1
debug ccsip
Jan 17 20:51:30.799: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=35552901060, Called Number=35552901060, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=35552901060
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Jan 17 20:51:30.799: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=35552901060, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
Jan 17 20:51:30.799: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Jan 17 20:51:30.799: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Jan 17 20:51:30.799: //-1/A6E9DC6E76CD/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=35552901060, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
Jan 17 20:51:30.799: //-1/A6E9DC6E76CD/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Jan 17 20:51:30.803: //-1/A6E9DC6E76CD/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=150, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=150
   Result=Success(0) after DP_MATCH_DEST
Jan 17 20:51:30.803: //-1/A6E9DC6E76CD/DPM/dpMatchSafModulePlugin:
   dialstring=150, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Jan 17 20:51:30.803: //-1/A6E9DC6E76CD/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20002
   Result=SUCCESS(0)
Jan 17 20:51:30.803: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=150, Called Number=150, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 17 20:51:30.803: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 17 20:51:30.803: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 17 20:51:30.803: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=150, Called Number=, Voice-Interface=0x0,
Jan 17 20:51:30.807: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 17 20:51:30.807: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jan 17 20:51:30.807: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 17 20:51:30.807: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 17 20:51:30.807: //-1/A6E9DC6E76CD/DPM/dpMatchPeersCore:
Jan 17 20:51:30.807: //-1/A6E9DC6E76CD/DPM/dpMatchSafModulePlugin:
   dialstring=150, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Jan 17 20:51:30.807: //-1/A6E9DC6E76CD/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 17 20:51:30.811: //13290/A6E9DC6E76CD/SIP/Call/sipSPICallInfo:
Looks like dial-peer matching is working and the dial peer for the ephon-dn is located.
Are you still getting "Disconnect Cause (SIP)   : 403" in the sip debug? Can you post latest debug for this call?
